iFIX Copy Object Animation
aiki202
Aug 2007
Pennsylvania
178
Is there a way copy an object's animation settings to another object? This is a very simple task in InTouch but I cannot find a way to perform this task in iFIX. Is this possible?
Yep...saves a ton of time.
While on the subject InTouch also offers a copy/paste function of the objects themselves where once you paste the first object you position it to the offset you want from the original object...then when you paste again the next object is perfectly spaced in both the X and Y direction without needing to align (vertically and horizontally) every object you paste. Just press Ctrl + V for each additional object and...well you're done.
64
Dear all, I am beginer in ifix hmi programming. I have 2 ifix 6.0 pc with license FiX and client.. Can some one tell me how to configure sample...
178
177
Hi everyone. I'm beginner with Ifix. I'm appreciate if you share me some document to understand how to play with Ifix 6.0. By the way, I have some...
755
Hi everyone. Ifix scada is new for me. Please help help me to clarify is it possible to open Ifix scada runtime on dual monitor and how to do? Thanks
470
