IFIX licensing on a virtual machine
phuz
Jun 2008
Mohnton, PA
1,044
I went to install IFIX 5.8 on a virtual machine for development and when I used the cloud-based licensing utility, it would say "Activated Successfully" but still show itself as unlicensed. I tried numerous times to no avail and then installed a different licensing client. It said for the cloud-based activation, you can't be running it on a virtual machine. So I found a post on another forum that talks about hiding VM presence from software, and I added this to my .vmx file:
monitor_control.restrict_backdoor = "true"
After restarting the VM, all the solution provider licenses were showing as valid, without having to re-download them again. They were already there, just invisible because it knew it was running inside a VM environment. Unless I am missing something here, they expect us to run the software on a physical box (which I will not be doing).
Hi I have a ifix 5.5 application where the operator opens a valve by clicking on a screen object. I can trace from object to data base that it is...
41
Dear all, I am beginer in ifix hmi programming. I have 2 ifix 6.0 pc with license FiX and client.. Can some one tell me how to configure sample...
158
Hello, I have to deal with iFix again and am looking at the most efficient way to create alarms to display in iFix, i.e. not creating an...
165
Hi everyone. I'm beginner with Ifix. I'm appreciate if you share me some document to understand how to play with Ifix 6.0. By the way, I have some...
722
Hi everyone. Ifix scada is new for me. Please help help me to clarify is it possible to open Ifix scada runtime on dual monitor and how to do? Thanks
447
