iFIX PowerTool to Database manager (array)
honda4life
Feb 2009
here
Hello everyone,
I have a problem with linking PowerTool to the Database manager,
Here are some screenshots:
As you can see the connection is good
And I get a value "10", so far OK
As you can see, this is an array, but I want the first 32 bits into a Digital Register
so I pointed the database manager to:
Code:
Simulator;Motoren;[Standard_Rockwell]MOT_CMD_Table0[0],L100;No Access Path;;/0
No value, changed to:
Code:
Simulator;Motoren;[Standard_Rockwell]MOT_CMD_Table0[0];No Access Path;;/0
every bit i checked with .F_# is now "1"
So i changed this from Digital Register to Text...
Now my value is 10
What am I doing wrong with the Digital Register?
use digital register & try with .F_CV instead of .F_1,F_2...or text block.
else use digital input block for reading the values or digital output block for wriking the values.
Note: The extension for DI, DO, DR should be .F_CV
Hi I have a ifix 5.5 application where the operator opens a valve by clicking on a screen object. I can trace from object to data base that it is...
43
Dear all, I am beginer in ifix hmi programming. I have 2 ifix 6.0 pc with license FiX and client.. Can some one tell me how to configure sample...
161
Hello, I have to deal with iFix again and am looking at the most efficient way to create alarms to display in iFix, i.e. not creating an...
166
Hi everyone. I'm beginner with Ifix. I'm appreciate if you share me some document to understand how to play with Ifix 6.0. By the way, I have some...
730
Hi everyone. Ifix scada is new for me. Please help help me to clarify is it possible to open Ifix scada runtime on dual monitor and how to do? Thanks
452
