IFIX SL4 Driver
Jeff.Hamilton
Sep 2022
Texas
I am trying to address an analog I/O point in an S7 300 PLC with the IFIX SL4 power tool. What is the address format for the datablock configuration? I can do digital points using I: and Q: but I cannot do and analog input.
Never used that driver but in Kepware it's
Discrete Inputs
ED00000-ED65535 (E is German I is English)
DWord, Long, Float
However, normally in S7 program PIWxx is the normal way to access I/O directly as a 16 bit word.
DB's
DB1-N.DBD00000-DBD65535
1-N is DB Block Number
DWord, Long, Float
For example : DB10.DBD2 (note: DW are 2 bytes so D0, D2, D4 Floats are 4 bytes so D0, D4, D8 & so on
Perhaps this may help but it may depend on how the I/O driver deciphers the addresses, not all suppliers use the same.
I'm using a S7-300 system with ethernet to a PC with Step 7 and that's working OK. On another PC I've got iFix 4.5 and the SL4 driver. It...
4,301
I need to add a new data block to an existing PLC. In SL4 Power Tool we have one channel with 11 PLC’s hung of it. If I bring the PLC I want to...
3,268
63
Dear all, I am beginer in ifix hmi programming. I have 2 ifix 6.0 pc with license FiX and client.. Can some one tell me how to configure sample...
174
175
