TSAutomation
can anyone open a IFix project and let me what tags are being used.
I will post the project if someone can
thanks
thanks
SLC_Integrator said:Depending what version of app you have you can just use the software as a demo and open up your app.
Call your local GE rep and I'm sure theyll have a CD laying around.
The demo version will run for 2 hours then shut down if it does not have the key but otherwise it is fully functioning.
Regardless if you still want someone to have a peek PM me and I can open it up.
“Error number: -2147211513(80042707)
Your hardware key allows runtime use only. Workspace will start in run mode.”
Power off, remove the hardware key/dongle, power on. You now should be able to get into design/program mode.
I did not understand C:\Dynamics\FIX.EXE /t you can me explained
