ifix3.5 & dual monitor system
e_pramod
Feb 2005
29
I have dual monitor & have to run two different screens in Intellusion scada application simulteniously.
How?? Please help.
The only way is to use a client station, this will cost you.
The only other way is to use a reverse KVM switch with two monitors, keyb & mice however this means what appears on one monitor will appear on the other, both can have control but not at same time (esc key is usual way to take control).
If this is acceptable then Black box do one or RS do a cheaper version.
Well, in Fix32 you could (IIRC) copy view.exe and run it again.
I don't have iFix 3.5, only 4.x and you can't do that with workspace.exe.
However, just span the desktop across both monitors and design the pictures to fit only one monitor (size wise) and then you can have two open at once, a left one and a right one.
I'll second parky: Have one SCADA node and and an extra View nodes. Or a blind SCADA and two View's.
Hello! Can someone please help me? I have a project at work where I have to work with iFix 3.5. The task is to combine the two HMIs, i.e take...
3,623
I have an existing Ifix PIC that is reading a SQL table when an down time timer times out. The operator clicks on the popup, choose a button with...
3,347
How can i connect ifix3.5 with Simatic 5.4 plcsim (simualator)... I have already connected simatic plcsim and wincc 6.2.... i have no idea with...
1,606
Dear All, We want to setup new iFix3.5 SCADA node to interface with Modicon PLC and wish to setup old node with Fix7.0 (now working as SCADA...
3,466
82
