Ignition Scada - Trending
DwSoFt
Mar 2012
Alberta
961
Hi Guys. I haven't really spent much time on this yet, and I will also be posting in their forum, but i wanted to pick your brains.
Currently the trends have a slider bar for adjusting the range (stock).
My one client would like to have a calendar drop-down for start and end date/times.
I am not sure how to bring this into the easy trend, but I have set up the start and end calendar's to make the selections.
You should be able to add the popup calendar component, 2 of them one for start one for end. Then bind start date, end date properties of the easy chart to the popup calendar components you added. Put the 'chart mode' to manual to hide the slider bar.
I tried what you said before but I must have had it in the wrong place, as I currently have it working.
I have the following scripting to set the starting points when I click the trend button
system.tag.write("[Client]TrendStart", "[System]Gateway/CurrentDateTime")
system.tag.write("[Client]TrendEnd", "Yesterdays Date")
And then I have dropdown calendars for the trend.
The reason it didnt work before is because I was looking towards the bottom of the trends properties, where the start up selection and i have it set to 1 day for this trend, but missed up higher where it has the actual start and end properties to link to the pop-up calendars.
Thanks Paully.
The more i do in ignition the more i love it.
You're welcome, it's nice to actually be excited to work with a SCADA platform than cringe isn't it?
you mean like with FTV SE? Haha
Yes it is, it is very adaptable. There are some limitations, but there are also workarounds usually.
Im kind of excited to see how the non-java based Ignition 8.0 will be when its released.
Hey Everyone, I need to Interface Ignition SCADA ethernet network to an Allen Bradley SLC5/04 Serial RS232 DF1. Has anyone out there found a low...
1,024
I can't seem to find a clear answer on this. Say you have a plc and an hmi with ignition to control the plc(and of course all other things you do...
5,215
Hi all, Looking for recommendations on some ethernet cameras suitable for hygienic/washdown areas, that I can embed into an Ignition SCADA...
2,378
Hello All, I've not tried Ignition yet but it looks good. It looks to be aimed at factory level automation so I was wondering if anyone is using...
3,655
Hello: I just thought some of you may want to see a report that we take from Ignition Scada. I work in the Oil & Gas Industry and this is a...
1,837
