f16bmathis
I'm sure I know the answer, but...
Can you wire an illuminated E-Stop 120 VAC so the power to the E-Stop when removed (button pushed) from the E-stop circuit, will then power the LED illuminated E-Stop light?
I only have the two wires coming to the E-Stop, though I could run the power to the LED then to the conduit ground, but that sounds unsafe also.
I think I need to run a third wire to do this correctly.
Thanks!
Thanks!
