i'm in problem Plz help me in PLC question
qu.student
Mar 2011
qatar
Hi all
i'm new her , i really want help with this question i totally don't understand it i think put nothing come in mind plz help because that question may come in my exam
the Question is :
Students are requested to write a programmable logic controller program using ladder diagram language to perform the required control algorithm (The required program should control PLC outputs based on PLC inputs)
1- Press the start Button ( should be hold for 5 seconds)
2- Start moving piston (A) from point (a) to point (b)
3- When piston (A) reaches point (b),start moving piston (B) from point (a) to point (b)
4- Move Piston (C) from (a) to (b) and then retract it back after 3 seconds
5- Move piston (A) back from point (b) to point (a) and move piston (B) from point (b) to point (a) in synchronized motions
6- Wait 10 seconds
7- Move piston (B) from point (a) to point (b)
8- Move piston (B) back from point (b) to point (a)1
9- Repeat the cycle again
- If the emergency button is pressed, the program should be stopped immediately
The start button should be pushed again to re-run the machine
At the top of this webpage there is a link named "learn plcs". Unless you have a specific question about something you've already tried to do on your own, that link will be the limit of the help you'll get here. You've got to give it some effort on your own first.
yes i know that i have to do it by myself but i tried but i don't know how to do it .. it is not an assignment or quize it'e for me which will help me in exam so plz help :(
i understand the concept i know that the first steup it should be hold which mean for example i have to press the button and not move my hand until 5 second and it is usful yo put timer BUT i don't know how to draw the ladder diagram so plz help you will not lose any thing
why do you need to learn plc , you would work in qatar , believe me , you don't need to learn anything, you will pass the exam
I suggest you start with sorting your signals into inputs, outputs, timers and don't-knows.
The ladder will be a development of this:
!--!input!---------(output)--!:nodi:
Kalle
hey evry one i have this problem In the system with S5 CPU 927 it is work ok, but i try to run another four CPU 927 for backup but no one of the...
3,899
my name is danish i am using keyence KV24r plc, i want to pick it's data serially to HMI through OPC i have try KEPserverEX matricon and INGEAR...
2,824
On all pages of my project i have a lot of information, texts and details that should not not be shown. I can remove them for each part apart from...
40
Hi, I have had problem with upgrading some projects from v16 to v18. I tried it on 3 diffrent computers. I want to post this so that anyone that...
173
Hi, I am having a challenge installing a new drive ACS355-03E-44A0-4 as it keeps on displaying Fault code F00018 even when the load is not...
135
