IM153-2 and DP/PA coupler and IO
Greet
Aug 2003
Mol
58
The machine now:
- 1st S7-rail with CPU and 8 IO-modules
- 2nd rail with IM153-2 and DP/PA coupler(FDC 157-0)
My question: we need another digital output- and inputcard, but we don't have any more space on the first rail.
I don't know if its possible to integrate this in the 2nd rail ?? Or is there another possibility, or do i need another rail... ?
As far as I know, you cannot add IO modules to a DP/PA coupler rack.
You have two options, if you want to use S7300/ET200M IO:
1) Add a rack extension, with an IM360/IM361 or a pair of IM365s
2) use it as remote IO, with either a PN or DP interface module.
On the Siemens IM153-1 Interface Module, ET200M, what is the difference between the "0 X-18/19/20" and the "1 x-8/9/10? Picture attached of the...
1,280
Hi All Good morning, I need an urgent help. I'm at the sight over the weekend and can't get hold of technical support. Problem is I have...
1,694
when we go online in the simatic hardware configuration, we have an et200 station IM153-2 redundant, which has a small red line at its top left...
1,974
I'm using TIA as software , after configuration S7-315 and connected with IM153-4 by profinet ,and download and go online , all the modules which...
2,568
Guys, I have an s7 315-2dp (2ag10) with remote i/o running on an et200m module. On the remote i/o rack there is an analog input module (6ES7...
1,975
