IM308-C Upgrading
No you can't. The S7 and S5 PLC's use different hardware and software. You'll need a new rack and a new S7-400 PLC to start with. You should be able to use the existing PROFIBUS I/O as it is. The software has to be rewritten. You can convert certain parts of the software with a tool from Siemens but this doesn't work for every function. It all depends on how complex your software is.
Do you have any other cards on your S5 rack or only an IM308?
No other Card Only IM308C.
OK, the only thing you need then are the GSD files to configure all your PROFIBUS slaves. It would also be handy if you have the COM PROFIBUS configuration files.
Dear Expert, My Simatic S5-155U Cpu 948 In stop led is on. When i connect my profibus cable to cp card CPU is going to Stop Condition after 13...
24
13,608
I have a rather unusual and confusing app in which I need to develop a PC Based HMI in WinCC Flexible to communicate with an S5 155 (948U CPU) via...
6,135
Hello, What should i expect to loose if i parametrize this module (6ES5 308-3UC21) with COM Profibus v3.0 (free of charge version, and i have)...
1,909
Hi everyone; I need to change the configuration of an IM308-4UA12 module. For that, I need the old "COM ET100" software. The zipped package is...
2,516
Hi, I am upgrading a Wonderware SCADA form version 9.5 to version 23. I am able to migrate all the graphic, but when to activate the runtime this...
446
