randy said:
How do I post an image of a RSLogix program?
thanks
rmonroe
http://www.wisdom-soft.com/products/screenhunter.htm
Link to a screen capture program
then capture, rename and upload images using the
Additional Options -> Display Pictures
Press the <CTRL> + <PrntScrn> button on your keyboard. This copies the screen contents to the clipboard. Open MSPaint. Select Edit - Paste. Now use MSPaint tools to remove anything you don't want in the picture and trim the picture down to a reasonable size. Save it as a JPEG or GIF. Then follow the steps GIT linked to.
The free Screenhunter program automates all of those steps
I am working with Twincat 3. I am trying to store some images in files and when PLC restarts I want to read those files and get the images...
59
Scenario: This is for a system that has a PV800 user interface (connected to a Micro850 PLC) programmed with CCW. There are various control...
560
Ran a firmware update on a datalogger and this is the horrific splash screen it showed when the update is running. Genuinely thought I'd bricked...
1,304
Hi, When I use an interrupt OB (let's say OB38 which is processed every 10ms), does it read the state of the inputs at the time it is called, or...
18
2,428
How to add animated images to factory talk view se When importing.gif images, it's not working
408
