Importing Tags into Citect
Engrlife
Aug 2017
British Columbia
41
How can you import tags into Citect from Unity and Rslogix5000? It seems ridiculous for a SCADA software made by schneider cant bring in a .xvm/ unity exportable file directly. It seems only possible to import .csv files in citects format
I cannot seem to find a solution as to how to import I/O tags from RSLogix onto C-more. Bits and counters populate just fine, but there is no I/O...
1,347
Good afternoon, I am new to programming the PanelView series from AB and need some help with getting my tags to work on the HMI created by OEM. I...
2,037
Hi, Ive had this issue with vijeo designer for a while where every time you do a complete rebuild of the plc program in unity pro you would need...
1,572
Ive been looking into switching some projects over that currently use PanelView Plus 6 600's to using Panelview 800's. Since the aforementioned...
1,919
I used a .CSV file to import tags to RSLogix 5000. There is a red octagon with a white X directly to the left of some of my recently imported tag...
1,756
