Importing I/O Tags from Logix5 to C-more EA9
ConnorCM371
Jan 2021
Georgia
I cannot seem to find a solution as to how to import I/O tags from RSLogix onto C-more. Bits and counters populate just fine, but there is no I/O.
Furthermore when I went to add them all in manually, I saw that discrete variable bits are only able to have bits up to 15 even though Logix labels bits up to 17 since 8-9 are skipped. This means Inputs like I:0/16 and I:0/17 cannot be created as tags in Cmore...
Any help with either of these issues would be great!
I can't help you with this specific application, but in general terms, I would avoid addressing I/O directly on any HMI, from any PLC. There are way too many problems caused, and many of them wind up being very difficult to troubleshoot.
Always map to/from an N register for HMI work. That will at least resolve the bit-numbering issue.
You may want to test any bits 9 and above. PLC5 uses octal addressing and the CMORE driver *MAY* use decimal addressing. If that is the case, I:0/16 in the PLC 5 would actually being I:0/14. I do not know if this is in fact the case, since I don't have a PLC5 laying around to test, but it would be a worth exploring.
Good afternoon, I am new to programming the PanelView series from AB and need some help with getting my tags to work on the HMI created by OEM. I...
2,037
How can you import tags into Citect from Unity and Rslogix5000? It seems ridiculous for a SCADA software made by schneider cant bring in a .xvm/...
1,146
Hi, Ive had this issue with vijeo designer for a while where every time you do a complete rebuild of the plc program in unity pro you would need...
1,571
Ive been looking into switching some projects over that currently use PanelView Plus 6 600's to using Panelview 800's. Since the aforementioned...
1,919
I used a .CSV file to import tags to RSLogix 5000. There is a red octagon with a white X directly to the left of some of my recently imported tag...
1,756
