In Touch
Jezz
Dec 2002
Kendal
399
Due to a tech problem with the lap top I have ended up with a copy of an Intouch Program (just the folder) on a floppy and have installed InTouch on my desk top (with the licience from the lap top) the problem is when I try to open the new project I get a message saying it's still under development on the Laptop.Is there a way round this or do I just have to wait till the laptops back????
Jezz
It has been a while since I worked with Intouch but if memory serves me correctly, when one starts to edit an Intouch application a file is created in the same folder...a sort of temp file like you have with MS Word. I cannot remember the filename but I know once you delete it, you should be able to edit away to your hearts content.
Hold it...stop the lights...memory flash...I think the name of the file is appedit.lok. I could be wrong now but it's worth a shot.
Intouch
Backup the folder so ou're happy you have a fall back..
Look in the folder for a file called applogic.lbk
Delete it !
Try it now ...
Hi there,
Don't you have a copy (CD) of Intouch 7.1 the manual is on it. It gets installed together with Intouch. The Step for communicating with Siemens S7-300 is on the on the CD I/O servers. I received a box which contained every software of wonderware, such as Inbatch, Incontrol ect, for free from my supplier. You can work with it without a licenses, but you need to restart every 2 hours.
If you can't get the software I could send the CD's to you by Mail.
Kind Regards
Hi
I have Intouch v7.1 CD and their manuals, but I want a simple manual because I don't understand the configurations of communication.
Thank, :)
Carla,
I've tried to send you two times a communiction manual according S7 but each time a got an undelivered status. Can you check your e-mail adress and your available memory space.
On the IO-server cd is also a file which contains the manuals for communication with a S7 plc and it's called IOSRV_S7.pdf.
Bye
Fritz,
I need a manual for the communication of the intouch v7.1 with Simatic Step7 v5.1. Help me to get this!!!! :) :) :rolleyes:
Best regards,
Carla
I have a problem, I'm running an AE Licence Manager on a Windows 2016 Server, and my Window Maker is on another separate Windows 2016 Server. My...
40
I require remote access to my projects that are away from home. I did some homework and decided that Weintek looked to have a good solution. Set...
210
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
144
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
149
Trying to export a Modern application for an upgrade to Intouch 2020 but I cannot export the application from the 2014 version because the export...
136
