increase memory for program
Oct 2013
kashipur
We have plc in which we can store only one program at a time, and we want to increase it by upto 10 program.
please suggest is memory of plc can increas or we have to change our old plc.
thanks
Without knowing which PLC you have... and without a little bit more of information... Typically PLC's have only one program running, what you can typically do is having more tasks (which I don't think is what you are after) or using recipes or so...
You could use an array of structures as a recipe or recipes if the PLC you use allow them to get different machine behaviours depending on the "program" choice.
If you are running out of memory though, there's not much you could do.
But, please extend your question.
Dear Experts, We are currently in a project commissioning stage now of a Biomass Plant. The above mentioned CPU is used. 2 days ago, our load...
2,635
Hello all, When i download new programs to S7-400 old type CPU with 8MB flash card attach, error is coming " memory bottle neck problem " and...
22,705
What has been your experience with year over year price increases on your Tech-connect service contracts? Is it up to the distributor? 30% seems...
290
I want increase the length of string from 82 to 150. By default it comes 82 is it possible to do so in Studio 5000
630
Hi everyone. I have a micrologix 1400 HSC reading a prox on a 40PPR large diameter (12") gear. This gear has large trapezoidal teeth. 500 RPM max...
41
12,495
