Indexing Table
PERSPOLIS
Jun 2002
ontario
295
HI EXPERTS
I WOULD LIKE TO GET INFORMATION REGARDING RORARY TABLE WHICH CONTROLLED BY A DRIVE WHAT ARE THE IMPORTANT FACTOR WHICH WE HAVE TO CONSIDER AS FAR AS PLC IS CONCERNED REGARDLESS THE NUMBER OF STATIONS, FOR EXAMPLE START STOP TIMER TIME DELAY ETC.
MANY THANKS EXPERTS
You don't give a lot to go on here.
We've used pneumatic driven and DC motor driven cam tables as well as hydraulic herth coupling type tables
I don't believe we ever made any selection of an index table based on the electronics. It's always the mechanical end of things that defines the table. Fixture & Part Mass, required accuracy, required index time, ability to withstand the work forces etc...
Now, if you meet those criteria and the selected table has a choice of control options then you can balance your familarity with your budget with the ease of programming etc.
If you want specifics, you'll have to provide more info on what the table cycle is going to be like
HTH
Good morning this may not be the ideal place to ask this question but any help is appreciated. It is machine controls related. I'm currently...
7,036
System: RS5000, CompactLogix L32E, PanelView +, Ver 15. I have a index table (6 Positions). On the table, it has 2 cylinders and a vacuum for...
2,738
Greetings, We have an osa-lator 90 degree indexing table in a robotic mig and spot welding cell that has been taking teeth out of the gears on the...
3,928
Hello, I'm in the process of converting a slicer from an Ultra3000 drive to a Kinetix 5100 using the KNX software version 4.00. The current...
537
Hello! The equipment I'm working on uses a lot of indexed tags I guess you'd call them. I thought it was indirect addresses maybe but all the...
1,061
