Indirect Addressing Extremely limited in MicroLogix 1400
Jul 2007
Kiruna
600
Am I right in saying that indirect addressing cant not be accessed at file level in these PLCs?
i.e N[x]:1 where x is pointer to address
it accepted it here, assuming the target addresses actually exist. While offline, if the indirect value (your x) points to an invalid file you'll get a warning. If, during running, it actually gets to an indirect instruction with the pointer still wrong you'll probably get a fault.
I expanded N7 and added N9, N10 and N11
I entered 9 in N7:5. I entered 10 in N7:6
I entered the instruction MOV N[N7:5].1 N[N7:6].1
It accepted it.
If I changed N7:5 to hold 12 and tried to accept it gave me a warning
"WARNING: File number doesn't point to the correct file type!"
Yeah, I get them a lot. I use indirect cycling through members of files (the last number) using indirect. If I save the values from the running program many times the number is one past the last valid point. it's ok as, before the sequence begins again, I reset the number back to the beginning.
Contrologix used to totally freak out if, during the pre-scan, the indirect would have resulted in an incorrect addressing. I don't think it does that any more.
Howdy folks, I am an Allen Bradley guy currently living in an Emerson world. Working with Rx3i on PacSystems Machine Edition v. 9.6? i think...
621
Hello, I'm very new to programming with absolutely zero schooling in this field and pretty hands off training in my new role, it's been fun...
668
Hello Friends, I am trying to index M Bits, however GX Works2 is not allowing it with following message. https://ibb.co/zPcqj6M...
1,381
Hi All, which the best way to do the indirect addressing in an optimize DB? Ccurrently this is my partial code inside an FB...
2,274
Hey everyone, Just used the PLC5/Logix migration utility to convert a program, and while addressing the PCEs, I noticed a lot of errors for "XIC...
1,985
