Indirect addressing in a UDT - RS Logix 5000
May 2011
South Carolina
87
I am sure everyone is saying not this again. I have looked and could not find an answer to this. I created a UDT with elements DW0, DW4, DW8, DW12, etc. all the way through DW60. All of these are of the type DINT. Then i created a new tag named DB16 of this UDT type, so now I have DB16.DW0, DB16.DW4, etc.
Now I want to use indirect to pull the value out of a different DINT depending on a previous add function. I tried to address it like DB16.DW[M34] and I keep getting an error saying "Invalid member specifier". M34 is also a DINT used as the location of the result in the previous add function.
It is apparent that for some reason you can not indirect address like this, but how would I do it then?
Can't do it like that....don't create individual members in your UDT.....create a Dint array in the UDT called DW of length 60...or 61 if you need an address at DW [60]. Then you can use the syntax you're trying to do.
Howdy folks, I am an Allen Bradley guy currently living in an Emerson world. Working with Rx3i on PacSystems Machine Edition v. 9.6? i think...
654
Hello, I'm very new to programming with absolutely zero schooling in this field and pretty hands off training in my new role, it's been fun...
685
Hello Friends, I am trying to index M Bits, however GX Works2 is not allowing it with following message. https://ibb.co/zPcqj6M...
1,407
Hi All, which the best way to do the indirect addressing in an optimize DB? Ccurrently this is my partial code inside an FB...
2,294
Hey everyone, Just used the PLC5/Logix migration utility to convert a program, and while addressing the PCEs, I noticed a lot of errors for "XIC...
2,040
