Indirect Addressing - wildcatherder's ML1400 Issue
kamenges
Nov 2002
Green Bay, WI
4,332
wildcatherder arrived at a satisfactory resolution to his question in this thread. I'm just not sure how since nothing was ever really resolved. So, based on his recommendation I am starting a new thread.
wildcatherder's assertion is that an indirect reference of N7:[R6:0.POS] "doesn't work" on his ML 1400. That's all we know at this point. Since this has worked on the platforms I have used (I have never used a ML 1400) I am curious what doesn't work. To that end:
When you tried this, what happened? Would the rung not validate? Did it validate but fault the processor when you loaded the program? Did it validate and run but return a value inconsistent with what you believed to be in the address referenced by R6:0.pos? If the last is the case could you determine the address it WAS pointing to?
Also, did you try to dereference using R6:0.2 instead of R6:0.POS?
Keith
The question I have about his other thread is which (see example below)rung did he try to do.
To me rung zero below would not give the intended results ( whatever they are) because the control (R6:0) would over write the .POS number the next scan.(or next time it incremented)
Rung One should work just fine.
Both rungs verified without errors, in my offline program. I don't have a ML1400 to download to.
Howdy folks, I am an Allen Bradley guy currently living in an Emerson world. Working with Rx3i on PacSystems Machine Edition v. 9.6? i think...
625
Hello, I'm very new to programming with absolutely zero schooling in this field and pretty hands off training in my new role, it's been fun...
670
Hello Friends, I am trying to index M Bits, however GX Works2 is not allowing it with following message. https://ibb.co/zPcqj6M...
1,387
Hi All, which the best way to do the indirect addressing in an optimize DB? Ccurrently this is my partial code inside an FB...
2,278
Hey everyone, Just used the PLC5/Logix migration utility to convert a program, and while addressing the PCEs, I noticed a lot of errors for "XIC...
1,989
