Indramat Servo - Open PAR file - How?
Oliver Micka
Oct 2015
Hlohovec
65
Hi everybody, i have back up´s from Indramat Servo Drivers, but those file have suffix PAR.
Drive1.par
Drive2.par
Does anybody know, which program or software i need use to open it and chceck all parameters ?
I tried Indralogic, DriveTop.. ( neither cant open a "par" file ) :sick:
Using IndraWorks ML (14V22) Select the TOOLS menu tab, select File Viewer, and select View and Compare parameters. Navigate to your .par file in the popup window for source A. Once it is loaded you can open the file in Editor. (selection icon on right side) You can then view/edit all parameters.
I see you can also view/edit all from the compare window as well without opening the editor.
I need help to see parameter list on Indramat DKC01.3 servo drive by going online. Which software, interface cable should use to communicate with...
3,424
Hello, I've got an Indramat Servo Drive that is a DKS 1.2-W100A-D base unit that has died on me. I have found quite a few DKS 1.1 floating...
2,083
I need some opinions on Indramat servo motors and controls. We are about to buy a feed system that has Indramat servo's. I always try to use...
3,813
Hello All, We just smoked 7 indramat drives. They power up on 24vdc and once you clear the e-stop circuit, that is when 3 phase 480 is applied to...
5,039
I've powered ON some machines after 18 months, & found 10 Out of 27 Indramat TDM drives not working. What could be reason for this failure
12,501
