OkiePC
any gotchas i should be aware of?
Ways to make sure the data is loaded before the screen opens?
Yes:
1. Alarms. You need alarm tags to be unique and dedicated.
2. Troubleshooting. You may cause some WTF moments for those who follow you and need to alter your work.
3. Entry limits. Are your data entry tags going to all share the same data entry limits? Are you going to have to do all the entry limits in the PLC so they can be unique? Does this mean the HMI can't display the entry limits for each tag accurately on its built in pop-up keypad?
4. Timing and cached tag values. You may have a situation where you change screens and, although within a couple milliseconds the PLC has changed all the tag values accordingly, the HMI is still using its cache of data for display until it has polled all those tags again. It might be acceptable or it might be so ugly that you need to hide it from view for a second or two.
