Infrared viewer (photoeye alignment)
rootboy
Jan 2004
Tennessee
1,375
I'm looking for a infrared viewer to see the infrared "footprint" of a photoeye's beam. I used one of these about 20 years ago, but I've forgotten who made it.
For those that haven't used one, it's the bomb for aligning photoeyes and reflectors. Just have someone stand behind the reflector with a sheet of cardboard and simply look through the viewer.
The infrared beam will show up as a circle on the cardboard. Then you simply align your photoeye so that the beam covers the reflector.
Swap places with your helper, and then adjust the reflector so that the return beam hits the photoeye.
Does anyone here use one?, and can anyone recommend one?
And finally, can I do the same thing with a nightvision scope?
Thanks.
Yup, I believe you are correct. I could probably do it with my Panasonic camcorder.
Thanks. :)
If your cellphone has a camera it can "see" IR too. I use mine to look at all kinds if IR stuff (remotes, etc.) to confirm operation. Sensitivity could be a problem depending on the amount of ******t light.
Von
The deleted text is supposed to "******t". Why deleted?
Why is it deleting a m b i e n t ?
because a m b i e n is a drug on the "bad word list" for this particular forum software. That particular word, along with v i a g r a and c i a l i s tend to show up in a lot of spam postings.
Hi there guys, For our process we need to monitor with a sensor the temperature of a wood log in a mill. That sensor need to be about 6 feets...
1,341
At some time in the past, someone told me about a card that you could hold in the path of an infrared photo emitter that made the beam visible...
1,445
We have a customer with Thermocouples and RTD's for temperature control. This temperature measurement system is not working for them as the read...
5,362
Hello, Does anyone know of a good non-contact temperature controller? Thanks, Dave
1,953
Anybody have any recommendations on an industrial infrared remote/receiver? We have a piece of equipment that has basically 4 functions that...
2,130
