Hi there,
Interesting problem today...
I have been using the same code for sometime and all of a sudden my initial values are not being set/used. They are all 0 and for the life of me I can't figure out why. The weirdest part is that I have put the same code on multiple PLC's. Some work correctly and others dont. I have had 1 case where 1 worked and then stopped working. Any ideas
I have been troubleshooting all morning and have tried every possible option but I am not against going through something again so have at it.
My setup is a DVP-SX2 connected to a Delta HMI.
Some side notes:
I can set values I have access to in the HMI and they seem to save once I do that.
The same code is used throughout, even uploading working plc's code and dropping into another doesn't work.
Thanks!
Some side notes:
Thanks!
