IMM retrofit is a very complicated undertaking unless you use a pre-packaged solution such as AB's PROSET. Most people here are underestimating the complexity of this project by an order of magnitude.
Open-close-squeeze and squirt you think that's all there is to it?
Hardly. I have retrofitted a molding machine years ago using the AB's QDB module.
I did not use the Proset.
To begin with, if you are going to do your own controls you will need to have a deep understanding of the molding process.
Judging by the posts, most people here don't.
They are trivializing it.
AB's QDC module was specifically developed to control Inject as well as clamp sides of an IMM. It is undoubtadly the most complex module that AB has ever developed.
There are literally hundreds of parameters that need to be intialized. I think that with QDC I needed about 27 block tranfers just to start the module up.
You think that if a general purpose motion controller could do the job that AB would go through the huge expense of developing this module?
Incidentally I was involved with this right at the bleeding edge of it. That's when late Frank Dyke and Dean Giancola were still in charge.
Actually some of the scaling values are based on my feedback.
On the inject side you need to do RAM pressure vs position, RAM pressure vs time and you need the capability to switch over
to pack/hold based on RAM pressure OR position OR time OR cavity pressure. You will need to control the shot size, pre-suck back, post suck back and screw rotation.
General purpose motion module can't do all that. In addition you have to control the clamp side.
we have worked long and hard at make the transistion from position to pressure control very smooth
I have no idea what this means.
There is no transition from position to pressure control.
The RAM pressure is profiled vs position or time. The switch over to pack/hold is based on position, time, RAM pressure or cavity pressure.
How can generic motion controller deal with cavity pressure?
AB has a built in ERC which is a tuning process automatically
adjusting PID parameters based on last few parts produced.
Generic motion controller will not do that.
How will generic motion controller deal with RAM pressure vs time profile?
How will it deal with screw rotation, suck back and shot size?
This off loads the PLC so it can to the temperature controls, HMI and safety interlocks.
You also have to control the clamp, core pull sequences, slide core interfaces, knock outs and robotic interfaces.
Finally, the HMI screens always seem to take the most time to write and get right.
I agree with that I had to develop over 100 sreens to have a state of the art IMM control. That is a major undertaking.
Finally there is a question of hydraulics. Having reliable
P/Q type valve for your inject is a must. I suggest that you contact Norm about this. Bosch- Rexroth are the leaders
in this field and you will need hydraulics expert to
help you select and size the valves.
