Inserting Photos in Posts Here
Dayvieboy
Jun 2013
San Francisco Bay Area
132
If you attach more than 1 photo.
They do not show up in the body of the post?
Is that a limitation or am I doing something wrong?
Thanks,
Dave
Once you upload your attachment. use the paperclip to select attachment to enter the file inside the post.
Then your post will look like this:
I think you understand the Forum software function correctly.
In my experience, a single attached image file will appear at the bottom of the post, but only if there is only one attachment. I know that works for .JPG and *.PNG files.
Because that is sufficient for most of my purposes, I haven't (despite being a forum member for a very long time) spent time learning and using the Insert Image feature for links to hosted-elsewhere or hosted-by-PLCTalk images.
I tend to prefer not to tell a story in multiple images, but sometimes it's necessary. I try to trim mine down in size; Paint.net is my go-to utility.
This forum's software is relatively antiquated, but it's free and stable and seems to suit its community well.
yes, by default, one image will automatically display, but more than one will show up as attachments.
However, once you upload the image(s) in the [attach files] dialog, you can insert an image ...
by clicking its name in the popup that comes up when you click the inverted triangle next to the "paper clip" icon
Like that.
Weird; until I logged out and logged back in, all of the inserted images above only appeared as attachment links.
My advice: if your narrative requires several screenshots, make sure you trim them down to size and add annotations or highlighting so you get the most storytelling value out of that screen space. Like drbitboy did !
Hi Guys, I am running an ABL33ER on firmware 33.12. I noticed that when I insert the SDcard into the controller the program stops. Not only that...
1,847
Hello, I'm new to AutoCAD and had some questions. If I make a border at roughly 8"x11" or something like that... How do I insert something that...
3,333
Morning all Using Studio 5K v 29 Lets say...........engineering changes a design :shoot: I started my I/O tree and now I needed one more...
1,532
How would I search an array of 52 SINTs for an available space (0) then move a (1) into the first available space?
29
9,701
I work for a company with many sites and we are installing a new process on one of our machines that mirrors another factories setup. Our...
1,595
