Inserting SDcard crashes PLC!
Paul_Pereira
Jan 2023
Amsterdam
51
Hi Guys,
I am running an ABL33ER on firmware 33.12. I noticed that when I insert the SDcard into the controller the program stops. Not only that. The program gets deleted from the PLC and I need to redownload the program. What could cause this?
Hi Guys,
I don't have an L33 on hand to check. Is the program set to load from SD card on power up? If that were the case, and the SD card were empty, perhaps the program in the PLC would be lost.
Just a guess.
Just a guess.
The card is not empty. It has the program loaded on it. And it was not a power on scenario. The sd card was just pushed into the plc while it was running. Any other reason?
I found out that there was some destructive code using cf big write that crashed the plc when the ad card was suddenly inserted. Inhibiting the cf tasks in studio 5000 solved the issue.
If you attach more than 1 photo. They do not show up in the body of the post? Is that a limitation or am I doing something wrong? Thanks, Dave
1,384
Hello, I'm new to AutoCAD and had some questions. If I make a border at roughly 8"x11" or something like that... How do I insert something that...
3,333
Morning all Using Studio 5K v 29 Lets say...........engineering changes a design :shoot: I started my I/O tree and now I needed one more...
1,532
How would I search an array of 52 SINTs for an available space (0) then move a (1) into the first available space?
29
9,701
I work for a company with many sites and we are installing a new process on one of our machines that mirrors another factories setup. Our...
1,595
