Install input module on Redundant system
Jan 2013
california
32
Hello
I would like some guidance on the correct way to install a new input module on a redundant Control logix system using control net on a remote rack and between the processors. The processors are 5561 L6 using revision 16, the card i want to install is a 1756-IB16IF DC fast input card. Am i going to need to update the firmware for this card to work? also my main concern is the control net portion of this, once i update to a newer firmware (Rev 19 as i heard it has the least amount of issues) will i then need to update all the firmware in the control net comm cards as well? also on the Ethernet Comm cards? i am not to familiar with control net. Is there anything that i should be aware of before attempting this firmware upgrade? Thank you.
Hi! So my problem is a little funky, I had Studio 5000 v 24 and 30 installed, but forgot to install RSLogix (which I cannot go without). Is there...
124
does anyone have an install or know if/where i can download it for the following "ABB PS501 Control Builder Plus V2.3 " the software was a free...
92
Hello, We have two stand alone FactoryTalk Site Edition clients running. Recently we've had a problem with FactoryTalk Linx on one of them. After...
107
Hi Deal All I had a issue With Rockwell Software try to download HMI but always give error (Unable to the Load Application) then rest the PC but...
115
