Install older series RSL5000
ceilingwalker
Mar 2010
Phoenix, AZ
1,586
Hello. I would like to know if I have a v.20 registration for RSL5000, does it also contain all previous versions? I ask because I have a CompactLogix CPU and as I try to open it, it pops up a warning that I must change what I have in the CPU or load the support for the current version of what is running in the CPU. Would the previous versions be on the RSL5000 CD? If so, am I able to have support for more than one version of the software? Thank you.
The simple answer is that your license will activate most Versions of RSLogix 5000. If you have v20 but need to open a project written for v17, you can install v17 off the installation DVDs.
While you need to install support for each Major Revision separately, in general you can have many Versions of RSLogix 5000 installed, but since the product has spanned the lifetimes of several major Windows versions, there are some limitations in OS support. I have versions 12-19 on an XP virtual machine, and 19,20,21,24 on a Windows 7 VM.
There are at least three more complex answers:
1. Very old versions of RSLogix only supported the old diskette-based activations. Anything older than Version 9 won't be activated by your FactoryTalk Activation. Unless you're trying to work on a system that's more than about 10 years old, this is not a problem.
2. You might have an Edition mismatch, not a Version mismatch. RA sells reduced-feature "Compact" and "Mini" editions of RSLogix 5000 licenses that support only CompactLogix and not the full size 1756 ControlLogix. You would need a license upgrade if that's the case. The Help ->About in your RSLogix 5000 installation should tell you which Edition you have.
3. The contents of the installation DVDs has varied over the years, as the bundled software has grown, RA started including fewer older versions on the DVD, so you need a TechConnect support agreement to download them.
The details of what was on each DVD are in RA Knowledgebase article 29461 (Access Level: TechConnect).
If you have v20, the odds are good that your DVD includes all the versions back to v12 or even v10.
Thank you Ken (y)
Careful with version 20. There are minor revisions that are not compatable. I hear there is a v20.04 that will fix but I have not tested.
Hi! So my problem is a little funky, I had Studio 5000 v 24 and 30 installed, but forgot to install RSLogix (which I cannot go without). Is there...
123
does anyone have an install or know if/where i can download it for the following "ABB PS501 Control Builder Plus V2.3 " the software was a free...
89
Hello, We have two stand alone FactoryTalk Site Edition clients running. Recently we've had a problem with FactoryTalk Linx on one of them. After...
104
Hi Deal All I had a issue With Rockwell Software try to download HMI but always give error (Unable to the Load Application) then rest the PC but...
115
