Install STEP5 on Win7
Toxafin
May 2018
Saudi arabia
hi all,
im trying to check EPROM of siemens PLC U115 CPU 943B , and as i found its required STEP5 software but the required OS is Win xp or older so is there any way to operate step5 on win7 or is there anyway else to check EPROM ...
thank u,
Maybe on a VM running XP, I would get S5 for Windows
https://www.ibhsoftec.com/S5W-Eng
Also you will need to use a serial to USB adapter for the TTY cable but the Siemens software will not let you use a USB adapter so your PC will need a true serial port
If you have an important machine or process that is running with an S5 CPU, and you cannot migrate to a newer PLC in the short term, then I would follow genius' advice and get S5 for Windows and the USB adapter. It is not even that expensive.
If you choose to try to install Siemens STEP5 in a VM, then you still need an adapter to go online. The USB adapter from IBH works also with Siemens STEP5 (V7.16 or higher).
I was never able to get a USB adapter to work with Step5, only S5 for Windows... if there PC has a serial port then they can just use a serial cable but most W7 machines do not have serial ports
Hi! So my problem is a little funky, I had Studio 5000 v 24 and 30 installed, but forgot to install RSLogix (which I cannot go without). Is there...
124
does anyone have an install or know if/where i can download it for the following "ABB PS501 Control Builder Plus V2.3 " the software was a free...
90
Hello, We have two stand alone FactoryTalk Site Edition clients running. Recently we've had a problem with FactoryTalk Linx on one of them. After...
105
Hi Deal All I had a issue With Rockwell Software try to download HMI but always give error (Unable to the Load Application) then rest the PC but...
115
