Installing AB Studio 5000
elfmanp
Feb 2011
Salt Lake City, Utah
18
In the past I have always installed all of my AB software in, and ran on a Virtual machine, specifically VMWare. However, with the release of Studio 5000 I am wondering if I shouldn't forget the Virtual Machine (VM has changed their free license to non-comercial use only) and install directly on my computer. Opinions, thoughts, issues, etc are invited... Thanks in advance.:confused:
Yes, I have been using VMWare Player, but it is now "not for commercial use". I had just been told in the past that AB software integrates itself so much in the operating system, it could mess up your operating system. Therefore installing in a virtual machine is much easier to roll-back/backup and not be quite so much work to restore.
Also, I am running a computer with Windows 7 on it.
I run VMware Workstation (not free). It's essential for my work with RA software. With all the different versions, a VM is the only way to go. And if an install goes bad, the snapshots will save you hours if not days of headaches.
I have Studio 5000 installed directly on my Windows 7 64-bit system w/o issue.
In reality you should get the proper license from VMWare as I would not recommend all software to get installed on a host machine (cough FT View ME). Go with Workstaion or Player (requires a Fusion license), it's $250 or $100 pending what you get, cheap considering.
It's worth the cost. Definitely go with the VM instead of installing on the host. I have VMs I can open from my home or work computers via USB. If my work laptop fails I can be up and running on a spare laptop very quickly even while my host is being repaired or replaced.
I too was disappointed in VMware changing to non-commercial use, I recommended it to co-workers and we used it in the classroom, but now all of those uses are not in compliance with their TOS.
OG
Hello all, I'm installing Studio 5000 Logix Designer on Windows 10, and I have this issue. When I installed Studio 5000 on Windows 7 (using the...
6,884
Never had to do this before, but I need to add the 1783-ETAP Add-On Profile to my system. I'm following the instructions here, and all goes well...
1,929
Hi all, I'm setting up a new field laptop and need Studio 5000 v21 and v29. Now I remember there were some issues with v21, something about...
7,543
I am having trouble installing v21.03. I currently have v19 and v20, installed no problem. I get an error message when the install wizard is...
1,928
Hello PLCS.NET! I'm sure a lot of you have to do downloads/installations of Studio 5000 on your PCs. I thought I'll point out that even though...
42
35,347
