Installing RSLogix 5000 on Win10Pro
micky
Aug 2003
DeRidder, La
83
I am trying to move an RS5000 21.03.01 install on a Win10Pro machine. Currently have this existing setup on another Win10Pro machine. The only difference this time is I am trying to install from RS5000 software downloaded from Rockwell as opposed to previously I had the DVD. It starts installing then hangs on "Updating files" then displays the attached error. Opened the log file don't see anything obvious as to what the issue may be.
Things I've tried
-Running it administrator mode
-Disabling UAC
-Running it in different compatibility modes
-All of the above in Win7 & XP VMs
What I am overlooking? The only thing I haven't tried is installing from the original physical DVD, which I don't have access to right now.
In the download go through the REDIST folder, then each subfolder one at a time and try to install or reinstall each item.
You will get popups that this is already installed, this doesn't apply to your computer and a newer version is installed, but when they are all done (and usually VisualStudio components are the main problem)
Then set the Compatibility of the installer to Win Vista SP2 and Run As Administrator.
I do this automatically with every new version on all Win10 PC's after many failures.
I have a possible project fixing a customer's old machine that is using a ControlLogix 5550... but I need to have v10 installed. Up to this point...
4,037
After trying multiple times to install Revision 19 on a fresh Windows10 Enterprise OS Laptop, I contacted Rockwell Support for help via Chat...
8,279
Hi guys, I've tried to install Rslogix 5000 V19 on Windows 7 Ultimate 32 bits but get a message that says "RSLogix 5000 is not supported on...
3,221
Hey all, Trying to install ver 17 of 5000, I have 16, 15, 13 already installed, just need 17 for a current project. It fails to install, looking...
8,694
I have versions 15 and 16 installed on my laptop, but I need to also install version 13 in order to view a client's old program. Is there...
3,438
