Installing syswin 3.4 on win7
Patrix
Aug 2011
Enschede
107
Hello everyone,
Has anyone installed syswin 3.4 from Omron on a win7 laptop. I'd tryed and think it works, but only in demonstration mode. When i insert the lincence key from my old laptop (manually) it says invalid key. I'd contacted Omron and they say they don't support it anymore and he had no clue either.
So i'd hoped any of you more smarter people had done this before and knows a sollution.
I have CX-One, but then i have to convert the programs to this version and then the adress symbols are way of from what they used to be. So i was hoping that i don't need to convert and retype all the adress symbols (can say i'm really bussy, but i'm just lazy)
Nope wont work either. Think i've got to alter the programs one by one.
Atleast thanx for replying Damian.
You could also try installing it inside Virtual Box or the free VM Ware VB - sometimes they work.
If you have a Syswin file you can open the SWP file directly in CX-Programmer - try 'open' and then have a look in the drop down box - the SWP file extension is there.
I have Omron v3.3. I did not install it yet. But I remembered last before hard disk crash, I installed it and no issue.
Try set the setup file compatible with XP or earlier version. I am using Window 7 ultimate version.
I would just open it with CX-P to be honest - I have mine running on Windows 7 x 64 bit.
A new point I/O rack is to be hooked up with the running PLC. In point I/O, it is supposed to be the OA4 card to be installed as per the...
108
During the process of installing Studio 5000 Mini Edition to my new machine at work, it seems as though some things like RSLinx Classic and the...
582
Hi All, I haven't installed Unity Pro in years and needed to install it recently. I initially tried installing Version 11.1 and the whole...
736
Hi all, I tried to install Twidosuite on windows 10 but after installing i have the registration link which is not working and also i get with...
585
I completely uninstalled Wonderware 2020 and all the related components, rebooted, and then tried to install InTouch 2012, but it won't proceed...
2,057
