Instrumentation Question
Unregistered
Guest
U
What is the difference between Loop response and Process Response?
I have looked through many books and on the web for this answer and can't get a streight answer. Can you help?
I dont know for sure but I will state what I "think" I know and maybe someone with more expertise will correct it.
Loop is a term used with something like PID control, the control is regulated by a feedback device. The response is the time period between input from feedback and correction of regulation.
Process response is the time period it takes for a device to activate...ie a plc turns on an output which in turns activates a solenoid valve which extends a ram.
Explaining things like this is not one of my strong points. I have stated it as I understand it but it may not be fully accurate.
I've spent most of my process control life in the chemical industry (over thirty years) and there it's not uncommon for process response times to last for hours or even days. Effectively these are actually PID loop response times, but because the times concerned are so long, they are usually referred to as Process response times.
Whether this can be transferred to other areas, I've no idea. The term may well have another meaning in other branches of industry.
Just a quick question for you guys. When you talk about "Loop-Powered" for instrumentation, will this term implies that the voltage require to...
3,036
My company is wanting to purchase a tool that will calibrate pressure transmitters. We have a lot of Foxboro and some Seimens pressure...
4,454
Please excuse if this is a naive/silly question, but... We have a panel with 208 VAC/3 phase coming in. I would like to use 24 VDC for all...
31
12,830
Hey guys! I'm a newbie in the control area, so I'm gonna drop some thoughts here... We want to control the opening of big silos (about 1900...
1,498
Hi, Just wanted some thoughts on protecting control and instrumentation from welding damage. We had a PLC and drive fail after some welding work...
5,032
