intellution comm alarms
SHOGAN....
Jan 2004
How do you stop comm alarms in intellution using abr i/o driver?
I,ve tried increasing access times decreasing scan rates nothing seems to help. The alarms only come in when the pc is rebooted, exactly 8 times every time. Only from one plc , I have 7 on the network, It's an NT machine.
Try this. You might need to download SIM ( software improvement module) from Intellution Site
Using SAC Command Line Parameters
FIX provides the command line parameters listed below with the WSACTASK.EXE executable file. These parameters do not use the slash (/) or dash (-) delimiters. Use the following format when entering multiple SAC parameters:
C Suppresses communication (COMM) alarms. This parameter must be last on the command line and requires a driver that supports latched data, such as FIX v7.x OPC servers.
Related Topics
Setting Up Startup Tasks
The Task Configuration Dialog Box
Copyright 1995-97, 1999, Intelllution, Inc. All Rights Reserved.
Mickey
hello guys following errors ocurrs during trying to starting mission program 1. workspace.exe has generated errors and will be closed by windows...
1,532
I was introduced to Intellution Fix32 scada software at one of my customers today. They have no support from the programmer that built this setup...
5,987
Hello! I am in need of the installation media för Intellution FIX32 version 6.1(or another version). I need to run it in trial mode to test a...
2,556
I am currently working on rebuilding a computer that had Intellution iFix 3.5 on it. The original installation disks have gone missing and unable...
2,524
Hello All, First off I want to admit I think I am in a bit over my head and need help. I have been thrown into a customers plant with a crashed...
3,299
