Interfacing ControlLogix with USS protocol
ekammeijer
Jul 2006
Costa Rica
I'm needing to communicate a ControlLogix Processor with serial and Ethernet communications with a Siemens MicroMaster M440 Drive that has USS protocol capabilities...
How can I interface both?
I'm really lost with this since I'm not familiarized with USS, and I need this to work with the ControlLogix.
Does anyone know of a gateway for USS/DF1, USS/DH485, or USS/EtherNet/IP conversion?
Thanks!!
The Data Station Plus (http://www.redlion.net/Products/HumanMachineInterface/DataStationPlus/DataStationPlus.html) can communicate DF1, DH485, and EIP, as well as USS and can be used as a protocol converter. The USS driver we have was devloped for the Simovert, unfortunately I am not very familiar with the Simovert or the MircoMaster, so I am not sure if it will work. Here is a link to the application note for communicating USS, maybe this will suit your application: http://www.redlion.net/Support/ApplicationNote/SimovertUSS.pdf
Regards,
Old thread, but looking into a similar application (will probably just put the drives on Profibus), but all I could find is you could in-theory make a Prosoft module work:
http://www.prosoft-technology.com/kb/article.php?id=365
[zombie post reply]
And, ProSoft also makes a full Profibus Master Module for Logix platforms. Really, it doesn't make sense to roll your own if you don't have to; especially if there will ever in the future be an upgrade or expansion to the system.
Now what fun is that for the end customer? In 10 years when everyone that was involved in the project is dead or gone and the new guy that has been there 2 weeks gets to reverse engineer what someone else did.
If you look at the development cost of rolling your own you spend more in man hours than the cost of the original card.
Good Afternoon , Thinking of replacing a Labeler with a brand , named EvoLabels ( Flexwipe ). Sounds like their communication is using Modbus...
1,907
Hello, I intend to connect to a ControlLogix 5571 PLC through a work station and program it. One way is to install the RSLinx driver and then use...
3,633
Good Morning , I have searched this subject, and found some threads dealing with this question and it seems like they have been a few years...
2,333
Hi Gents, I am required to interface with a Drive from a ControlLogix L-61. Has anyone any experience of this? Any recommendations of how I can...
4,163
I have a Cognex Insight 2000-130 camera that I'm trying to get talking to my PLC. Both are connected to the same router via Ethernet. Thus far...
1,268
