Interfacing Of Plc And Hmi
Wsandeep
Feb 2007
MP
Hi
Please help me to understand how alarm tagging to be done so that alrm desplay on HMI as soon as alarm condition declaired by PLC
plc monitor all inputs, and when input goes from off to on, or on to off, the change is sent by modbus or other protocol to the hmi.
and the hmi then does what you programmed it to do.
It is impossible to display an alarm on any HMI in existance "as soon as the alarm condition declaired by PLC".
An alarm condition in a PLC must remain in an alarm state for at least one complete polling cycle of the communications link between an HMI and a PLC.
Typical HMI's monitor a "Tag", which is connected to a data server, which is connected to a PLC. The Data Server only polls the PLC for information periodically. Even if you try to poll every millisecond, you won't be getting an accurate value for every point in the PLC every millisecond. Commonly, HMI alarming is polled on a 250, 500, or 1000 millisecond basis.
If you know that your data server is polling at 250msec or faster, than to assure that an HMI can 'see' an alarm condition, you must make sure the alarm condition is maintained for AT LEAST 250msec... and preferably, add 10% to that, so you want the alarm 'Bit' to stay 'Active' for at least 275msec.
(Caveat: If the HMI is PART of the PLC, as some smaller 'integrated HMI/PLC's are, it just might be possible)
Wsandeep said:
Hi
I recommend making the alarms in the PLC "latched" - that is, when the alarm condition occurs an internal coil is turned ON and a holding contact will keep the alarm coil ON until the alarm is cleared from the HMI. Then you don't have to worry about polling cycles
That's how we do it. Seal (or latch) the alarm bit that's read by the HMI. Break the seal (unlatch) with operator acknowlwdge button...
thanks
Thanks to all of u for helping me to understand the problem.
Now another problem, how can i see the actual motor rpm on pc with the help of siemens s-7-300 plc ,simatic VC drive,wincc scada and communication by profibus.
hello to all my question is can we interface a plc with a different brand of hmi using modbus communication. is it necessary that both the brand...
2,193
i need to interface a siemens PLC(300series) most probably 314ifm, with a HMI(LCD screen) and a personal computer for data aquisition, now the...
6,893
I try to interface the Panasonic GT11 Display with CP1H PLC. i want to display the values in memory address ex.D9000 in GT11 HMI In GT11 software...
2,221
hello i want to read temperature data from Masibus UT94 temperature transmitter which is giving data on RS485 port. i have assigned ID:-30 and...
1,063
hello, Can anyone help me regarding the logic of interfacing ELITE 440 energy meter with M200 PLC over Ethernet. Elite 440 is having Ethernet...
3,857
