plc with hmi interfacing
sonjacksy
May 2013
india
36
hello to all my question is can we interface a plc with a different brand of hmi using modbus communication. is it necessary that both the brand should be same for modubus communicaiton.
For the most part, Modbus should allow you to talk between one brand PLC and another brand HMI. Sometimes there is a little manipulation that needs done depending on how the PLC breaks up 32 bit numbers and how the HMI interprets them, but once you figure one of them out it is usually fairly easy from there.
What brand of PLC and HMI are you considering?
GE 90-30 to intouch
I am thinking my problem maybe cable related but here is my question. I have the address right and com settings. I have intouch linked to GESNP and the GESNP address set in the power supply port had the program cable trying to communicate but it just times out. I can not get it to communicate any advice would be helpful.
I'd recommend that you start a new thread for this question and provide more information, such as:
Which Version of InTouch?
Which Operating System?
Do you have true comm ports on your computer?
What is the cable that you are using? Is it the Horner 9pin comm port cable with the RS485 converter for the PLC port?
Which model of 9030 PLC are you using?
Which Version of the GESNP IO Server?
i need to interface a siemens PLC(300series) most probably 314ifm, with a HMI(LCD screen) and a personal computer for data aquisition, now the...
6,904
I try to interface the Panasonic GT11 Display with CP1H PLC. i want to display the values in memory address ex.D9000 in GT11 HMI In GT11 software...
2,221
Hi Please help me to understand how alarm tagging to be done so that alrm desplay on HMI as soon as alarm condition declaired by PLC
3,061
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an...
51
Hi, Wy we log data in PLC using DLG instruction, when we have option to log data in HMI
82
