Interfacing PLC with ID System
rickcet
May 2004
I am currently working on a project that involves interfacing a PLC with a ID system such as barcodes or RFIDs. I am not sure how to begin. My project consists of reading a tag on a conveyor line that will signal a CPU to make a program change. The tag will have only a number burned on to it corresponding to a program number. The layout consists of as following: The ID reader will read a tag. The reader will send the tag number to a plc. The plc will send the number to a CPU that will then make the changes to the system.
Any ideas on what type of plc to use and the background on what format the program number is going to be in when it goes from machine to machine?
I presume the connection to the RFID is serial. If so, you could use Omron CS1 or CJ1 PLCs. They have inexpensive serial cards that mount in the processor (CS1) or rack (CJ1 and CS1). The CJ1 is really rackless and mounts on a DIN rail.
You would then require CX-Protocol software. This would enable you to very simply put together a serial communication to the RFID. They could probably supply the RFID as well with the protocol already written.
Access to the information collected in the serial card is very simply performed by the PMCR instruction in the PLC. Read the number and change the program to another task.
You can access any serial device in this way. I regularly access Modbus devices and GSM modems for SMS messaging.
What do you mean by this? Do you mean the PLC you're using has NO CPU????
I once simply connected a barcodereader to a serial port (CP521) in a Simatic S5-100U PLC and this little beggar did all the processing needed. When using an Allen-Bradley CompactLogix I don't even need a separate serial port, especially if I'm using an -L30 version. Because that version has two serial ports on board, I can program the darn thing while it's communicating with the barcode reader.
Kind regards,
hi, i want to interface a 8051 based system to siemens s7-312 plc through a mpi cable ,so i can send some data to plc or receive from that. please...
4,666
hello i want to read temperature data from Masibus UT94 temperature transmitter which is giving data on RS485 port. i have assigned ID:-30 and...
1,073
hello, Can anyone help me regarding the logic of interfacing ELITE 440 energy meter with M200 PLC over Ethernet. Elite 440 is having Ethernet...
3,861
Can somebody help me with interfacing of Schnieder EM6400NG multi function meter with m340 plc using modbus. i want to read KW (Power) of load.
1,658
Hello All, Is there anyway of directly interfacing the Maxim 1 wire protocol to a PLC? Thanks Carl
2,281
