Intouch 10.1 AlarmDBLogger - SQL 2012
Otto_I
Feb 2015
Austria
Hello,
I have a strange problem. I have two sistems (A and B). An
these two systems, I have two PC-s. Sistems are separate. I have connection (PLC - Intouch 10.1 - SQL server 2012). Problem that I have is in sistem A alarms are working - they are written in DB if I restart PC. In sistem B alarms do not work - they are not in DB after I restart PC. I have Win7 32bit. With .bat file I start SCADA and alarmDBLogger. If I want the alarms to be written in DB I need to create now DB with AlarmDBLogger. I use also more users. One user is for PC (standar user). One user is global. The sistems are the same.
Hello,
I found the Problem. I unistall Intouch, and install it again. This time I used global user (by installation) and it works. I also do some modifications an SQL (Security, Logins,...) an sa user and user for PC.
I have a problem, I'm running an AE Licence Manager on a Windows 2016 Server, and my Window Maker is on another separate Windows 2016 Server. My...
38
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
144
Trying to export a Modern application for an upgrade to Intouch 2020 but I cannot export the application from the 2014 version because the export...
136
178
Currently we have a fat( I think that is what it is called) Intouch application. An application resolution of 3840x1080, and inside that 2x...
109
