Intouch 10 slow to 555 PLC
Goku
Feb 2007
Randburg
Hi, I've got a problem.
Got two 555-1106 PLC's connected with two 2572 ethernet cards to a CTI industrial switch. From there the ethernet goes to two Intouch 10 PC's.
The update to the PC's is very slow(5- 15 secondes). Sometimes when you start a motor on the one PC the running indication on the other PC will indicate and after e few seconds the used PC will only indicate.
I use CTI2572 IO Server and defined two topics. Each PLC with its own IP address. Should the Ports on the two PC's be the same or different? (Port number: 1505) At the moment it's the same.
The idea is to use the two topics in the redundancy of the Intouch.
The funny thing is that on my laptop I set up the same system on Intouch 9.5 and the update is fast!
Why? Ports? Intouch 10? Wrong IO Server Setup?
Hi. Importing a 2014 aapck in 2023: no problem using it, adding windows, works very well, no problem whatsoever. Creating a new project: as...
756
Hi, everyone I'm working with Wonderware System Platform and the InTouch applicaction is very slow. The graphics and the windows load really...
4,074
Hello, please help me. I have big problem with communication between DASSIdirect 3 SP1 and S7-417H. I communicate over 5500 tags. There is VERY...
3,849
Hi , i am converting a standalone app to a modern app with many archestra grapchics replacing the old classic ones.. . The thing is that each time...
2,207
Hello and welcome to intouch people, These days I am having problem with fetching trends in Intouch very slow...I don't know where to...
8,843
