InTouch - 2 station - history alarm synchronization
mactobi
Jan 2011
Gdańsk
Hi
I have the following problem. I have PLC Siemens S7-315 which is connected to 2 PC computers (with InTouch 10). Both computers are also connected to use NAD architecture. Now I need the both station to be redundant to each other.
1.I don't know how to synchronize history alarm between the station.
2. If one station will be offline and return after some time is it possible to synchronize the history alarm on this station?
Thanks for help
welcome to the forum, I´m not familiar with Siemens nor Intouch, but in AB platform I would setup a FIFO queue inside the PLC to save alarm history, with this approach it doesn´t matter if one of your PC is off, as soon as you turn it on it will display alarm updated.
I haven't tried it but you should be able to write a script to change the remote reference in the Alarm Query field of the alarm configuration window.
But I don't know how synchronize two SQL Express databases, or thera is another way two historical alarms in both station?
I have a problem, I'm running an AE Licence Manager on a Windows 2016 Server, and my Window Maker is on another separate Windows 2016 Server. My...
75
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
161
Trying to export a Modern application for an upgrade to Intouch 2020 but I cannot export the application from the 2014 version because the export...
139
195
Currently we have a fat( I think that is what it is called) Intouch application. An application resolution of 3840x1080, and inside that 2x...
112
