Intouch 7.1, PLC Siemens S7-300
sahibh
Feb 2011
Faisalabad
I am facing problem due to reinstalling system with Windows NT4 and Intouch, IOServer,Simatic Net OPC Server. Now it does not communicate with PLCs. It shows following error message "Error: Poking Item S7{L_76.........Processing Write False D_Watch_Dog_in" Somthing like this..
A propmpt response will be appreciated...
regards
i assume you are using OPC Link as a client? have you checked the configuration of your topics in OPC Link?
Have you tried communicating with the PLC using OPC Scout??
Are you able to ping the PLC IP address?
LH
LH
Yes I am using OPC Link as client, Actually I am totally new in Digital System so don't know more about OPC Link and its configuration anyhow i have checked network communication via PING command and verified OPC Link configuration while checking other OCUs of same systems. If you kinldy suggest me how to check and troubleshoot it it would be a favor.
when station configurator loads does the OPC Server and Ethernet connection show healthy and in Run???
When you formatted your system did you name the computer something different as it has to match your Station configurator configuration?
Post up a screenshot of your station configurator...
LH
Can somebody guide me how can i copy old nt4 based OPC configuration file to newly installed simatic net xp based information system becasue i have two other OCU running with old NT based OPC Server properly. Which are main configuration file and can work properly with new OPC Server ?
Greeting, I am doing some investigations on which driver(s) support tag based addressing (eg. Pump001_Running) rather than DB or Modbus based...
3,756
Hello Everyone, I use PLC S7-400 with Ethernet module CP 443-1 and i want to communicate with My galaxy via DAServer. I configure my PLC with...
3,422
This Problem happened many times, is it only because the wrong type DB10Q0 should be DB1010 or any other possible cause? HMI log file ...
8,571
Hello Guys! Well am totally new in the world of plc....and have worked little bit on wonderware intouch v 10 and Allen Bradley plc. Now I Want to...
4,719
hello, sir , i m having 313c siemens plc with usb adapter , i want to communicate it with wonderware's intouch , will it possible plz advice me,
3,557
