Intouch 7.11 Read Error
gizmo
Aug 2002
95
This is not really a PLC related question, but this site seems to be good with all types of questions.
When I attempt to open an Intouch 7.11 application, I get the following popup dialog boxes:
-- "READ ERROR" (the title of the dialog box reads "Problem Reading Tagnam...")
I click OK and get the next box.
-- DB cannot be loaded. Are database files ready only? or user has read-only access? Exiting WindowMaker.
-- Database initialization failure. It may be necessary to restart Windows before starting WindowMaker again.
Any help with this problem would be greatly appreciated. What kind of database files (give me a filename example) do I need to look for to see if they are read-only?
Thanks!
I had a similar problem opening an Intouch application. I'm working from my memory but I am sure the error messages were the same.
The problem was the license file was not installed on the computer I was using.
I installed the license and the application opened OK.
The other thing that can give you this problem is if you are trying to open the application from a CD. If you copy it to your hard drive don't forget to change the attribites of all the files from read-only. This has caught me out on a couple of occasions. :D
Follow Up
Thanks Nick,
I copied files from CD to Harddrive and only removed "read only" on the tagname and db files. I selected all files in the directory and removed "read only" and I'm back in business.
Thanks Again!
Hi, we have a Wonderware InTouch (v9.5) application that reads data from several older Compact/ControlLogix PLCs (v.15 firmware) using DASABCIP...
4,789
Hi, I'm trying to read twelve 500 arrays in InTouch, but i don't have enough tagnames to do that. I rewrite one array to 17 dwords in plc, but i...
3,892
Hi All I have installed my PC, WWIntouch 9.5,RS logix 5,OPC LINK 8, RS emulate and RSlinx 2.43. Well, I build a simple ladder in Rslogix 5 and...
5,312
I have a problem, I'm running an AE Licence Manager on a Windows 2016 Server, and my Window Maker is on another separate Windows 2016 Server. My...
35
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
144
