Intouch 9.0 I/O Message to S5
Now I use HMI Wonderware InTouch 9.0 Communication via I/O server Siemens SINEC H1 CP 1413 To PLC 135U CPU928B
and I need to send string data from HMI to Data block of PLC
I create I/O Message Tag define item DB243DW02KS
after I try to send data but ! nothing chang in plc
thank you.
Your syntax is incorrect, try:
DBxSy.v
where
x= DB no.
y= first data word
v= length of string
Hi All, I have a problem to export HistData Trend to csv file. When i click "Save to file" button in historical trend window at Windowviewer, i...
4,438
Hi, I‘m using a FC to decode a S7 string. Everything is working fine when I enter that string via PLC_SIM, but normally it should come from...
1,932
I want to show message status automatically follow to integer value in my data word of S7-300. For example DB1.DBW0...
3,076
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
135
Trying to export a Modern application for an upgrade to Intouch 2020 but I cannot export the application from the 2014 version because the export...
133
