InTouch SQL table's column comparison
manasi
May 2007
maharashtra
123
Hello All
how to compare SQL table's columns in InTouch and reflects result in InTouch Tag to start logging in another SQL table...
1. I have two different tables in SQL DB, Master table and Child table.
2. I have two compare two columns in Master Table i.e Product ID column and Status column. On Production start command receipt from InTouch app. (using Toggle button in Wonderware InTouch)
3. After the receipt of production start command from Wonderware, need to write a InTouch SQL script that will compare the columns of Master table mentioned above.
4. If there is a "NEW" text present in the status column against that times ProductionID then only start logging InTouch Tag (Product Temperature) in Child table created in SQL DB under temperature column.
Please HELP...
Manasi
Hi, I have an intouch 9.5 project passing data to a MS SQL 2005, all good so far. I want to upgrade my HMI project to 2014R2, and SQL to 2012, but...
1,120
I've tried following "Wonderware InTouch HMI Supplementary Components Guide" but the value from sql not appear on intouch runtime screen. I...
25
12,811
Hi, I want to connect the Intouch and MS SQL Server. But now I cannot access the SQL Server into MS SQL Server, the message was showing Invalid...
7,148
I have a wonderware standalone HMI collecting process data from our production line. I am writing those values to a database in MySQL, though I...
2,742
Hello, I have an Intouch application that I am using a Sql select script to retrieve information from a database...
5,793
