InTouch SQLGrid connection to OracleXE
twibs
Feb 2014
Satakunta
Hello.
I've no trouble connecting to the Oracle with the SQLconnect but I cannot figure what is wrong with my SQLGrid properties. It only gives "Failed to connect to the database server"
I'm bit new to the whole SQLdatabase so perhaps there are some basics I'm forgetting. I'm using Oracle Express 10.2.0.1. Been used here for a while so using 'safe'n'old' version. OS is W7x64.
My SQLconnect string
"Provider=MSDAORA;
Data Source=####;
User ID=####;
Password=####;"
SQLGrid properties
Authentication_dg: SQLServer
ConfiguredDatabase_dg: XE
ConfiguredServer_dg: (Same as datasource)
ConfiguredUser_dg: (same as user ID)
ConfiguredPassword_dg: (same as PW)
ConfiguredDoamin_dg: (empty, since not windows auth)
InstanceName_dg: (table name in database, for ref)
SQLQuery_dg: (table name I want to connect to)
SQLQueryCurrent_dg: (empty)
I have a problem, I'm running an AE Licence Manager on a Windows 2016 Server, and my Window Maker is on another separate Windows 2016 Server. My...
37
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
144
Trying to export a Modern application for an upgrade to Intouch 2020 but I cannot export the application from the 2014 version because the export...
135
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
177
Currently we have a fat( I think that is what it is called) Intouch application. An application resolution of 3840x1080, and inside that 2x...
109
