Intouch v23 Security issue
Radhik
Apr 2022
Wa
Suddenly my In Touch Windows maker stopped working for some reason. I've got two errors which might be the reason as far as i am concerned.
I can open windows viewer but not maker. Can see it is open in the background by moving the cursor over it but not letting it open.
Last few logs in attached file
OnLoad :: Object reference not set to an instance of an object., at WindowMaker.View.MainForm.DockManager_ActiveWindowChanged(Object sender, DockWindowEventArgs e)
at Telerik.WinControls.UI.Docking.RadDock.OnActiveWindowChanged(DockWindowEventArgs e)
at Telerik.WinControls.UI.Docking.RadDock.UpdateActiveWindow(DockWindow window, Boolean forceNotify)
at Telerik.WinControls.UI.Docking.RadDock.ActivateWindow(DockWindow window, Boolean forceNotify)
at Telerik.WinControls.UI.Docking.RadDock.set_ActiveWindow(DockWindow value)
at WindowMaker.View.MainForm.<OnLoad>d__144.MoveNext()
Please pass on any info.
Found the Solution. someone will need this one
Deleting the DockSettings.xml file from "[RootDrive:]:\Users\<User Name>\AppData\Local\Wonderware" fixed the issue
Hola chicos. Tengo un problema con el driver de comucicacion dasabcip 5, y un plc controllogix v34, ya realice la comunicacion pero en ciertos...
162
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
129
Trying to export a Modern application for an upgrade to Intouch 2020 but I cannot export the application from the 2014 version because the export...
108
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
149
Currently we have a fat( I think that is what it is called) Intouch application. An application resolution of 3840x1080, and inside that 2x...
91
