InTouch Window Viewer Alarms Language
mtariq_amin
Nov 2007
Jeddah
Dear All.
I am using InTouch Window Maker Version 7.1..
My All Alarms are appearing in Italian Language in Window Viewer.
I want all Alarms in English Language.
Is it Possible???
All other messages and screens are in English Language but Only the Alarms are in Italian Language.
Kindly help me regarding this matter.
Regards,
Tariq
The text for the alarm messages are contained in the tag descriptions. If you want to change them, you'll have to go into the tag editor and manually change each of them.
Or alternately, you should be able to use the DBDUMP option in the WonderWare startup menu to dump the whole database to a CSV file. Then you can make the changes using Excel (or any other spreadsheet or text processor), then DBLOAD them back into the program.
It's not terribly difficult to do, but it is time consuming if your application is very large.
Hi Guys, How can I run full screen on wonder ware Intouch window viewer?
5,832
Dear All, How I can set up the start up of window viwer automatically when windows started. Please not that I am using Archestra IDE to run my...
7,958
Hello, since i am starting using intouch, i need some help Actually i want to make in intouch a String input field. The operator has to insert a...
335
Hi guys. I am using Intouch Wonderware. Does anyone know how to enlarge the AlarmViewerCtrl properties window? In my case it is cut off as in the...
1,499
Hi there, Been working adding new pages and features to an existing SCADA and have encountered a strange error when it comes to the sizing of...
1,573
