intrinsically safe power
hiren gajera
Nov 2011
ahmedabad
Hi ,
Is any person know about intrinsically safe power supply?
I have to give power to HMI & pressure x'meter wich are at hazardous area.
Is it possible to convert normal 24v dc power supply (Phonix trio) to Intrinsically safe power?
Thank you.
It is not uncommon to see a standard power supply in the safe area used with an Intrinsically Safe (I/S) barrier for each I/S rated field transmitter, because the analog input the field transmitter connects to is in the safe area, and the power supply powers more than one field transmitter and the whole 2 wire concept lends itself to such.
Every I/S power supply I've ever seen states that it must be installed in a safe area, not a hazardous area. It sounds to me like you want to put a power supply in the hazardous area. The power supplies I've seen in hazardous areas are in explosion proof housings, so intrinsic safety is not an issue; the protection is provided by EXP.
Is your HMI really rated I/S ?
Hi, I have a Class 1 Div 2 HMI and would like to supply the 24 Vdc power through an isolation barrier. I cannot seem to find any barriers out...
19
4,158
It is my understanding that an LED is considered a simple device, making its use fairly simple in an IS application. However I am running into a...
22
5,896
I have a customer that is requesting an Intrinsically Safe HMI. I can't say that I've ever heard of an Intrinsically Safe HMI. Anybody here have...
17
4,572
Hey, does anyone have any experience with such a device? I need to have an RFID reader set up in one of the paint booths we have. Thanks! -PreLC
1,586
I had a chat today with a contractor and he notified me that Rockwell will stop producing the Flex Ex IO modules from December 31st. The ones we...
1,660
